Mains power voltage drop to reduce usage?...
  • Thread starter Commander Kinsey
  • Start date
On 06/11/2022 14:23, Commander Kinsey wrote:
Instead of rolling blackouts when there\'s a power shortage, why don\'t we
just allow (or deliberately) the voltage and frequency to drop?
Wouldn\'t that make a lot of devices use less?
It is a legal requirement to keep the frequency at 50Hz over a set period.
Therefore if it lags at any point they have to increase to catch up.
This was a legal requirement due to mains clocks.
On Sun, 13 Nov 2022 10:48:31 -0000, The Natural Philosopher <tnp@invalid.invalid> wrote:
On 12/11/2022 21:22, Carlos E.R. wrote:
On 2022-11-12 15:17, Commander Kinsey wrote:
On Sat, 12 Nov 2022 13:39:00 -0000, Carlos E.R.
robin_listas@es.invalid> wrote:
On 2022-11-12 14:22, Commander Kinsey wrote:
On Fri, 11 Nov 2022 17:55:38 -0000, rick
don\'t we
period.
But you can drop it to 49 for a while then put it up to 51 when there\'s
plenty power.
And do it in the entire Europe, simultaneously?
We\'re linked by DC, so no.
Wrong.
Yes, the European mainland grid whilst it is not all of Europe, is
synchronised.
I believe Norway, the UK and Ireland, are definietly totally separate.
I thought there was a problem with capacitance sending AC a long distance, hence DC to the UK? Yet they\'re managing AC throughout most of Europe?
On Sun, 13 Nov 2022 12:42:11 -0000, <upsidedown@downunder.com> wrote:
On Sun, 13 Nov 2022 10:48:31 +0000, The Natural Philosopher
don\'t we
period.
plenty power.
Wrong.
synchronised.
There us a good map of the various synchronous networks in Europe in
https://en.wikipedia.org/wiki/Synchronous_grid_of_Continental_Europe
It should be noted that some areas in North Africa is connected to
UCTE. Denmark is interesting, Jutland is in UCTE while the islands
are in the Nordic net.
The CIS (Russia etc) has an own synchronous network.
The situation in Ukraine is currently unclear.
That\'s just dust from the bombs, you\'ll get a good view tomorrow.
On Sun, 13 Nov 2022 07:56:00 -0000, <upsidedown@downunder.com> wrote:
On Sat, 12 Nov 2022 22:22:24 +0100, \"Carlos E.R.\"
don\'t we
period.
plenty power.
Wrong.
Most parts of continental Europe are connected to a single 50 Hz
synchronous network (UCTE). UK is connected to this network with under
sea DC cables. Scandinavia is also connected to this UCTE network with
DC cables. All these three networks are nominally 50 Hz but there are
phase differences varying all the time.
Due to the AC/DC/AC connection across the Channel UK could do some
strange thing with their network without affecting the continental
Europe.or Scandinavia.
What does USA do with it\'s 60Hz shit? Or does it do as it does with the rest of politics, ignore everyone non-American?
\"Commander Kinsey\" <CK1@nospam.com> writes:
don\'t we
period.
plenty power.
Wrong.
Support the largest and most successful economy on the planet.
https://www.csis.org/analysis/mapping-us-canada-energy-relationship
https://www.statista.com/statistics/189033/us-electricity-imports-from-mexico-since-1999/
don\'t we
period.
there\'s
plenty power.
Wrong.
synchronised.
of Europe?
They\'re not having to send it undersea though.
don\'t we
period.
plenty power.
Wrong.
Yes.
That is correct. What he said, was not.
Cheers, Carlos.
SteveW <steve@walker-family.me.uk> writes:
synchronised.
of Europe?
https://en.wikipedia.org/wiki/HVDC_Gotland
don\'t we
period.
there\'s plenty power.
That can in fact be done. And was done. And it wrecked equipment in
German factories, so they installed their own exactly 50Hz inverters.
I think the problem originated in one of the ex eastern bloc nations.
Yep.
Well, I wouldn\'t say that as proof \"it can be done\". There were
consequences :-D
Cheers, Carlos.
shortage, why don\'t we just allow (or deliberately) the
voltage and frequency to drop? Wouldn\'t that make a lot
over a set period. Therefore if it lags at any point they
when there\'s plenty power.
Wrong.
synchronised. I believe Norway, the UK and Ireland, are definietly
totally separate.
most of Europe?
There is a problem with capacitance and inductance sending high voltage
underground or undersea for significant distances, which DC doesn\'t have.
Cheers, Carlos.
On 2022-11-13 12:47, Martin Brown wrote:
Japanese kit can pretty much always be relied upon to work on either 50
or 60Hz since roughly half of their country is on each frequency.
Oh? I had no idea of that. Different islands, perhaps?
Cheers, Carlos.
On 2022-11-14 03:09, Commander Kinsey wrote:
On Sun, 13 Nov 2022 11:47:06 -0000, Martin Brown
\'\'\'newspam\'\'\'@nonad.co.uk> wrote:
On 12/11/2022 14:18, Commander Kinsey wrote:
On Sat, 12 Nov 2022 13:37:24 -0000, Carlos E.R.
On 2022-11-12 14:11, Commander Kinsey wrote:
On Sat, 12 Nov 2022 13:05:02 -0000, John Walliker
jrwalliker@gmail.com
wrote:
On Saturday, 12 November 2022 at 12:08:20 UTC, Commander Kinsey
wrote:
Why would an invertor disconnect at lower frequency? It should be
able to match any frequency.
Its a regulatory requirement.
That is not an explanation.  There\'s no reason to disconnect.
It is to me... If I am the engineer designing or installing an
inverter,
I have to follow the law and regulations.
No, you\'re *supposed* to.
And a puny domestic inverter will die horribly if it stays on too long.
Anyway, that doesn\'t explain why the regulation is there.  Surely an
invertor is capable of producing a sine wave at any frequency?
The semiconductor electronics are certainly capable of that but the
transformer will saturate and then get hot ultimately catching fire if
the frequency drops too low. Some US kit built for 60Hz only would get
awfully hot on UK 50Hz mains. A cheap and nasty US brand of shavers sold
mostly at Xmas relied on a 60Hz mechanical resonance for good measure.
Then it must be possible to let it go way below 50Hz.  The regulation\'s
a bit daft if some can do it.
No, because existing equipment can not handle it. The regulation simply
takes into account that equipment, those design constraints, and tells
you not to drop the frequency.
Sure, go to your own island and put your own rules, from scratch, then talk.
Cheers, Carlos.
On Thu, 17 Nov 2022 20:30:41 +0100, cretinous Carlos E.R., another brain
dead troll-feeding senile ASSHOLE, blathered
Why should he, you dumb spick, when he can go to these ngs and get fed every
day by troll-feeding useless senile assholes like you? <BG>
On Thu, 17 Nov 2022 19:16:00 GMT, Scott Lurndal, another mentally deficient,
troll-feeding, senile ASSHOLE, babbled again:
Not as much as you troll-feeding senile assholes in these groups keep
supporting, feeding and humouring the dumbest trolling wanker and attention
whore around! <BG>
On Thu, 17 Nov 2022 19:16:19 +0000, SteveWanker, another troll-feeding
senile ASSHOLE, blathered:
of Europe?
LOL The troll keeps engaging you senile assholes! And you senile assholes
are THANKFUL that he keeps doing so. You simply ARE such miserable senile
assholes! LOL
On Thu, 17 Nov 2022 20:20:30 +0100, cretinous Carlos E.R., another brain
There is a problem with the useless troll-feeding senile assholes in these
groups, you useless troll-feeding senile spick!
synchronised.
of Europe?
Except of course that that is DC link - because it is underwater.
Wrong.
totally  separate.
most of Europe?
More power can be sent through above ground lines too with DC than with AC.
Wrong.
totally  separate.
most of Europe?
This one runs about almost 1000 km and transmits 2000 MW
< if I\'m reading this correctly >
https://en.wikipedia.org/wiki/Nelson_River_DC_Transmission_System
Lots of very specialized engineering and other considerations
that distinguish it from long AC EHV transmission.
John T.
most of Europe?
.... to which one should add, the problems of corona (which requires fat cables
in air) and earth conduction (a leakage resistance that inductively couples to AC)
which limit all installations, even airborne lines that don\'t take the low paths.
