Mains power voltage drop to reduce usage?...
  • Thread starter Commander Kinsey
  • Start date
On Wed, 23 Nov 2022 15:25:10 -0000, Fredxx <fredxx@spam.uk> wrote:
On 23/11/2022 13:30, Commander Kinsey wrote:
On Wed, 23 Nov 2022 13:13:53 -0000, The Natural Philosopher
tnp@invalid.invalid> wrote:
On 23/11/2022 11:41, Max Demian wrote:
On 23/11/2022 11:14, Commander Kinsey wrote:
On Wed, 23 Nov 2022 10:00:06 -0000, The Natural Philosopher
Seawater is a good conductor, unlike air, so the cables must be
insulated, and that insulation forms the bulk of the dielectric.
That\'s why they had to be DC - charging and discharging that
capacitance
via a resistive cable cant be done 50 times a second without massive
losses.
Are all insulators dielectrics?
Potentially.
Ability to form a capacitor is connected to the formation of dipoles in
the material Monopoles are characteristic of conductors.
There must be some insulators which cannot form dipoles.
Only useful if you know what a dipole is, and an insulator.
I\'m quite sure the engineers making the inter-country connections do.
Of course taking into account, there is no such thing as a perfect
insulator, and no such thing as a perfect conductor, superconductors
excepted.
It doesn\'t have to a be a perfect insulator, just one that\'s rubbish at being a dipole.
On Wed, 23 Nov 2022 16:01:09 -0000, John Larkin <jlarkin@highlandsnipmetechnology.com> wrote:
capacitance
losses.
Potentially.
excepted.
Vacuum is a pretty good non-polar insulator. Er = 1. Insulation
resistance is excellent.
Its breakdown voltage is impressive, but enough voltage gradient will
rip atoms off any metal electrodes. Around 1e10 v/m as I recall.
It must be possible to make a vacuum in a big tube across the English Channel.
Actually.... why don\'t they run the cable in the Chunnel?
On Thu, 24 Nov 2022 05:47:31 +1100, cantankerous trolling geezer Rodent
Speed, the auto-contradicting senile sociopath, blabbered, again:
<FLUSH the abnormal trolling senile cretin\'s latest trollshit unread>
David Plowman about senile Rodent Speed\'s trolling:
\"Wodney is doing a lot of morphing these days. Must be even more desperate
than usual for attention.\"
MID: <59a60da1d9dave@davenoise.co.uk>
On Wed, 23 Nov 2022 19:42:15 +0000, Chris Green, the mentally deficient,
notorious, troll-feeding, senile idiot, blathered again:
? Looking at yesterday as a quick example on gridwatch wind is
nowhere near 40%.
And what does that tell you, you troll-feeding senile ASSHOLE? You STILL
don\'t get it? <BG>
On Wed, 23 Nov 2022 15:39:19 -0000, John Larkin <jlarkin@highlandsnipmetechnology.com> wrote:
That\'s why they had to be DC - charging and discharging that capacitance
losses.
Potentially.
With at least a relative permittivity of unity.
A negative permittivity would be fun, but violates conservation of
energy. Negative capacitors are easy; I did one as a school project
but it had a battery inside.
https://www.anl.gov/article/newly-devised-static-negative-capacitor-could-improve-computing
capacitance
losses.
Potentially.
excepted.
being a dipole.
I think we have discovered the problem in your understanding. An
insulator rubbish at being a dipole, would normally be called a conductor.
capacitance
losses.
Potentially.
excepted.
being a dipole.
Idiot. Different insulators have different dipole properties.
On Wed, 23 Nov 2022 20:58:37 +0000, Fredxx, the notorious, troll-feeding,
senile smartass, blathered again:
Have you, you demented troll-feeding senile smartass? <BG>
On 23/11/2022 13:34, Carlos E.R. wrote:
On 2022-11-23 11:47, Martin Brown wrote:
On 22/11/2022 16:32, John Larkin wrote:
On Tue, 22 Nov 2022 15:38:21 +0000, Clive Page <usenet@page2.eu
wrote:
On 18/11/2022 12:04, Martin Brown wrote:
I can\'t imagine anything that would cause a reasonable train
propulsion system to fail at 49 Hz, or even 45 Hz.
The fact that the UK mains distribution grid will drop them off load
at 48Hz has a lot to do with it. They represent a large \"pure\" load
(and so are a target once the usual intermittent supply folk have been
dropped).
Automated load shedding triggers at <48.000Hz.
Snag was that with the modern configuration of local solar panels and
wind shedding 1GW of domestic load also shed 600MW of local generation
so only made a 400MW net contribution. Rinse and repeat leading to a
cascade failure of a much larger section of grid than was strictly
necessary. It will almost certainly fail the same way next time.
Maybe the trains will have a boot from cold function added to their
firmware in future but I\'m not holding my breath.
What happens if they simply lower the Pantograph? I suppose they do that
eventually, when parked.
That\'s a good point. Locos are parked up with their pantographs lowered.
Surely it doesn\'t need an engineer visit to power them back up?
On Wed, 23 Nov 2022 21:10:02 -0000, \"Commander Kinsey\"
capacitance
losses.
Potentially.
excepted.
being a dipole.
I don\'t think a monatomic gas is considered to be a dipole, but their
Er > 1.
On Wed, 23 Nov 2022 20:48:52 -0000, \"Commander Kinsey\"
losses.
Potentially.
There\'s nothing new about a cap with a negative incremental c:v slope.
I doubt that one is going to revolutionize computing.
dropped).
I wonder if the engineers needed were actually train
drivers (which are sometimes called \"engineers\").
Jasen.
On 2022-11-23, Commander Kinsey <CK1@nospam.com> wrote:
On Wed, 23 Nov 2022 13:13:53 -0000, The Natural Philosopher <tnp@invalid.invalid> wrote:
losses.
Potentially.
\"Nothing\" comes to mind, that is, a vacuum can be used as an insulator.
Jasen.
excepted.
being a dipole.
Er > 1.
That\'s Stark effect; an imposed E-field changes the electron orbitals. In theory,
you could identify a nuclear perturbation, too.
On Wed, 23 Nov 2022 16:22:58 -0800, John Larkin, another mentally deficient,
troll-feeding, senile ASSHOLE, blathered:
> I don\'t think
That\'s right, you troll-feeding senile cretin! All you sick senile assholes
ONLY blather endlessly in your typical senile manner!
On Thu, 24 Nov 2022 04:01:43 -0000 (UTC), Jasen Betts, another mentally
handicapped troll-feeding senile idiot, blathered:
\"Nothing\" and \"vacuum\" describes you useless senile troll-feeding assholes
best! <BG>
On Wed, 23 Nov 2022 16:28:28 -0800, John Larkin, another mentally deficient,
Oh, lookie! Senile asshole Larkin STILL believes he could eventually win
this game! What a senile ASSHOLE indeed! You\'ll be in for a surprise, my
newest senile punching bag! LOL
dropped).
Surely the drivers would be stuck with the stranded locos in the first
place? Plus, engineers is not really a term used for British train
drivers, it is more an American term.
On 23/11/2022 19:07, Commander Kinsey wrote:
On Wed, 23 Nov 2022 17:57:33 -0000, John Larkin
We\'d be OK without power for a few weeks in our mild climate, but we
have some food and water and a propane BBQ.
Cooking is not required for survival.  Power for the freezer and fridge
is handy though.
It\'s impossible to live entirely on uncooked food. People try it, and
get rather sick after a time.
Max Demian
dropped).
that
Only in America. In the UK engineer doesn\'t have a particularly clear
meaning but in this context it means someone qualified to service
rolling stock prior to an ordinary driver taking it out on the track.
The train drivers were already in the cab when the power went down and
the trains all ground to a halt. Like their passengers they were unable
to leave until someone came and rescued them.
Indeed. In this case the software seemed particularly silly.
However, it didn\'t get noticed or dealt with until it caused utter
chaos. I can\'t believe that nobody had pointed it out as a serious
potential defect before it actually caused so much disruption.
It is exactly the sort of thing that design reviews are supposed to find -
What happens if the mains power fails?
How do we restart again safely?
Maybe they did and with the mechanical constraints of the motors mean
that the only way is to have a qualified systems engineer manually tweak
it into a safe condition where it can be restarted.
Regards,
Martin Brown
