Mains power voltage drop to reduce usage?...
  • Thread starter Commander Kinsey
  • Start date
On Wed, 23 Nov 2022 15:11:06 +0000, Fredxx <fredxx@spam.uk> wrote:
On 23/11/2022 11:41, Max Demian wrote:
On 23/11/2022 11:14, Commander Kinsey wrote:
On Wed, 23 Nov 2022 10:00:06 -0000, The Natural Philosopher
tnp@invalid.invalid> wrote:
Seawater is a good conductor, unlike air, so the cables must be
insulated, and that insulation forms the bulk of the dielectric.
That\'s why they had to be DC - charging and discharging that capacitance
via a resistive cable cant be done 50 times a second without massive
losses.
Are all insulators dielectrics?
Potentially.
With at least a relative permittivity of unity.
A negative permittivity would be fun, but violates conservation of
energy. Negative capacitors are easy; I did one as a school project
but it had a battery inside.
On Wed, 23 Nov 2022 15:25:10 +0000, Fredxx <fredxx@spam.uk> wrote:
On 23/11/2022 13:30, Commander Kinsey wrote:
On Wed, 23 Nov 2022 13:13:53 -0000, The Natural Philosopher
capacitance
losses.
Potentially.
Ability to form a capacitor is connected to the formation of dipoles in
the material Monopoles are characteristic of conductors.
There must be some insulators which cannot form dipoles.
Only useful if you know what a dipole is, and an insulator.
Of course taking into account, there is no such thing as a perfect
insulator, and no such thing as a perfect conductor, superconductors
excepted.
Vacuum is a pretty good non-polar insulator. Er = 1. Insulation
resistance is excellent.
Its breakdown voltage is impressive, but enough voltage gradient will
rip atoms off any metal electrodes. Around 1e10 v/m as I recall.
On Wed, 23 Nov 2022 15:16:29 -0000, John Larkin <jlarkin@highlandsnipmetechnology.com> wrote:
On Wed, 23 Nov 2022 10:47:47 +0000, Martin Brown
\'\'\'newspam\'\'\'@nonad.co.uk> wrote:
On 22/11/2022 16:32, John Larkin wrote:
On Tue, 22 Nov 2022 15:38:21 +0000, Clive Page <usenet@page2.eu
wrote:
On 18/11/2022 12:04, Martin Brown wrote:
I think they probably could increase the low frequency bound for domestic and modest sized solar or wind farms not to drop off grid. It is preferable to stress a few motors and transformers for a few minutes when compared to the major cost of dropping large segments of load.
Otherwise you get the cascade failure mode that afflicted the UK after a freak lightning strike took out a fairly small electric plant and caused a cascade of failures that took down mains for London and much of England.
https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/836626/20191003_E3C_Interim_Report_into_GB_Power_Disruption.pdf
It didn\'t help that electric trains required an engineering reset before they could be moved from where they ground to a halt when the mains went down.
It turned out that the design spec of the trains was that they should cope with a frequency drop to as low as 49 Hz, but they were built by German engineers who assumed that in a modern country like Germany, but not as it turned out the UK, the mains frequency could *never* drop below 49.5 Hz, so they built in (or failed to avoid) a serious failure mode when this actually occurred. Hence all their class 700 trains stopped.
Messrs Thameslink, the train operator, compounded the problem by only installing in some of their trains a software update which would have allowed the driver to restart the train after it had stopped from this cause. Since only a few trains could be restarted, the lines were still pretty well blocked, and the network was effectively at a standstill for about half a day. A combined German and British cock-up you might think.
I can\'t imagine anything that would cause a reasonable train
propulsion system to fail at 49 Hz, or even 45 Hz.
The fact that the UK mains distribution grid will drop them off load at
48Hz has a lot to do with it. They represent a large \"pure\" load (and so
are a target once the usual intermittent supply folk have been dropped).
Automated load shedding triggers at <48.000Hz.
Snag was that with the modern configuration of local solar panels and
wind shedding 1GW of domestic load also shed 600MW of local generation
so only made a 400MW net contribution. Rinse and repeat leading to a
cascade failure of a much larger section of grid than was strictly
necessary. It will almost certainly fail the same way next time.
Maybe the trains will have a boot from cold function added to their
firmware in future but I\'m not holding my breath.
Greenies-in-charge has just begun. Get used to cold and dark.
And hungry.
Already planning some battery backup here.
On Wed, 23 Nov 2022 15:22:58 -0000, John Larkin <jlarkin@highlandsnipmetechnology.com> wrote:
On Wed, 23 Nov 2022 08:25:55 -0000, \"Commander Kinsey\"
CK1@nospam.com> wrote:
On Tue, 22 Nov 2022 23:39:35 -0000, Carlos E.R. <robin_listas@es.invalid> wrote:
On 2022-11-22 23:08, Commander Kinsey wrote:
On Tue, 22 Nov 2022 21:06:22 -0000, John Larkin
But rails bear enormous loads and trains are very efficient.
Actually, they use more fuel per passenger than a car.
Not true.
It is true, a study was conducted in the UK. The weight of a train is ridiculous.
People are light and volume inefficient. Efficiency would be better if
people were properly packed and stacked in a rail car, like freight
and products are.
Now add in the train is never going exactly to and from where each person wants to be, and cars are way better.
Public transport is for poor people.
Here, trains are for rich tourists with time on their hands.
When I tourismise, I take my car.
On Wed, 23 Nov 2022 15:29:12 -0000, John Larkin <jlarkin@highlandsnipmetechnology.com> wrote:
On Wed, 23 Nov 2022 11:14:14 -0000, \"Commander Kinsey\"
On Wed, 23 Nov 2022 10:00:06 -0000, The Natural Philosopher <tnp@invalid.invalid> wrote:
On 22/11/2022 19:52, SteveW wrote:
On 19/11/2022 07:20, Commander Kinsey wrote:
On Thu, 17 Nov 2022 23:02:30 -0000, SteveW <steve@walker-family.me.uk
wrote:
On 17/11/2022 19:22, Scott Lurndal wrote:
SteveW <steve@walker-family.me.uk> writes:
On 17/11/2022 19:03, Commander Kinsey wrote:
Yes, the European mainland grid whilst it is not all of Europe, is
synchronised.
I believe Norway, the UK and Ireland, are definietly totally
separate.
I thought there was a problem with capacitance sending AC a long
distance, hence DC to the UK? Yet they\'re managing AC throughout
most
of Europe?
They\'re not having to send it undersea though.
https://en.wikipedia.org/wiki/HVDC_Gotland
Except of course that that is DC link - because it is underwater.
Underwater is irrelevant, it\'s the capacitance in the wire.
It is not irrelevant at all. Overhead, high-voltage wires are
uninsulated. Underwater ones cannot be and also have to have physical
(metal) protection. That alone turns them into very long capacitors.
Yes. When I visited as a teenager the very first UK-FR undersea link,
the engineers said \'if we switch it off and disconnect it, we can draw
an arc for half an hour from the stored electricity\'.
via a resistive cable cant be done 50 times a second without massive losses.
Certainly. Every insulator has a dielectric constant.
If you mean \"is every insulator suitable for manufacturing cables and
capacitors?\" some aren\'t. Gasoline and crumpled newspaper might be
poor choices.
But then, capacitive liquid level gages use gasoline as the
dielectric.
It seems the French are no good at such calculations. My Renault\'s fuel guage is very non linear. The second half of the tank is used twice as fast as the first half according to the guage. As for the digital \"miles left before running out\" reading, it seems to think I can get about 90mpg from a petrol engine. But luckily the average speed since you last pressed the button guage is very very accurate, so I use it for cheating the average speed cameras. People just don\'t get why I can go 100 in a 60.
On Wed, 23 Nov 2022 17:21:00 -0000, \"Commander Kinsey\"
And hungry.
We\'d be OK without power for a few weeks in our mild climate, but we
have some food and water and a propane BBQ.
People in really cold climates will be in serious trouble, especially
when heat is all-electric and the grid is powered by all \"renewables.\"
It might take decades to rebuild a reliable energy system, once people
come to their senses. If.
On Wed, 23 Nov 2022 17:24:22 -0000, \"Commander Kinsey\"
synchronised.
separate.
most
of Europe?
poor choices.
dielectric.
Everything goes through a computer now. Gas gages are probably
programmed to be alarmist.
On Thu, 24 Nov 2022 00:34:54 +1100, Carlos E.R. <robin_listas@es.invalid>
at 48Hz has a lot to do with it. They represent a large \"pure\" load
(and so are a target once the usual intermittent supply folk have been
dropped).
What happens if they simply lower the Pantograph? I suppose they do that
eventually, when parked.
Ours don\'t and that would be too much farting around imo.
On Thu, 24 Nov 2022 05:11:13 +1100, cantankerous trolling geezer Rodent
Speed, the auto-contradicting senile sociopath, blabbered, again:
<FLUSH the abnormal trolling senile cretin\'s latest trollshit unread>
\"Who or What is Rod Speed?
Rod Speed is an entirely modern phenomenon. Essentially, Rod Speed
is an insecure and worthless individual who has discovered he can
enhance his own self-esteem in his own eyes by playing \"the big, hard
man\" on the InterNet.\"
https://www.pcreview.co.uk/threads/rod-speed-faq.2973853/
On Wed, 23 Nov 2022 09:57:33 -0800, John Larkin, another mentally deficient,
troll-feeding, senile ASSHOLE, blathered:
WTF has your trollshit got to do with any of the 3 ngs you keep crossposting
it to, you senile piece of shit troll?
On Wed, 23 Nov 2022 07:22:58 -0800, John Larkin, another mentally deficient,
trolling and troll-feeding, senile ASSHOLE, blathered:
You mean like you two trolling subnormal cretins? <BG>
On Wed, 23 Nov 2022 15:25:10 +0000, Fredxx, the notorious, troll-feeding,
senile smartass, blathered again:
excepted.
You sick old asshole already KNOW what the troll is about. You whined about
his trolling already dozens of times ...and YET you can\'t resist taking his
baits, time and again! Goes to show just HOW senile you are, you ridiculous
senile smartass! LOL
On Wed, 23 Nov 2022 07:29:12 -0800, John Larkin, another mentally deficient,
The one constant here is that you can\'t stop sucking troll-cock, you
miserable senile cocksucker!
On Wed, 23 Nov 2022 10:00:39 -0800, John Larkin, another mentally deficient,
the trolling and troll-feeding senile ASSHOLE, blathered again:
You STILL haven\'t realized that you are talking to a clinically insane
sociopathic wanker? LOL Just HOW senile are you, you subnormal senile
shithead? LOL
On Thu, 24 Nov 2022 04:57:33 +1100, John Larkin
segments of load.
at
so
dropped).
And hungry.
Nope. They are free to wear lots of winter clothes and even just stay in
bed.
especially
That last will never happen anywhere.
Nope, the french proved that you can do mostly nukes quite a bit quicker
than that.
On Wed, 23 Nov 2022 17:57:33 -0000, John Larkin <jlarkin@highlandsnipmetechnology.com> wrote:
And hungry.
Cooking is not required for survival. Power for the freezer and fridge is handy though.
No, heating is a luxury. In the shelter of a house, and wearing a jacket, people wouldn\'t even be uncomfortable, nevermind dead.
The UK is 40% wind power. If they can multiply that by 2.5, we would be fine.
And hungry.
On Wed, 23 Nov 2022 18:00:39 -0000, John Larkin <jlarkin@highlandsnipmetechnology.com> wrote:
synchronised.
separate.
most
of Europe?
poor choices.
dielectric.
Mine is the wrong way round, both the guage and the predicted miles left. Both are telling me I can go further than I can, risking me running out of fuel.
? Looking at yesterday as a quick example on gridwatch wind is
nowhere near 40%.
Chris Green
nowhere near 40%.
True enough, I\'ve often seen it only 30%. But if it\'s lower, another country will be higher. Lots of big wires between us, the whole world could run off wind.
