S
StevWolf
I have a dead Ac/Dc adaptor. I\'m busted it just to learns stuff.
Im trying to learn how to test Transformers. This transformer says on it AMS10405 RG 1320F. I provide this to give all information, however Im not sure it matters much to my question.
I have so far removed from what I can gather are the Primary wires from the board. I assume they are because they are white and black and are literal wires going into transformer, as oppose to all the other connections which appear to be pins in the circuit board. I believe to properly test transformer you need to remove it fully eventually.
Here are my results with digital tester, When set to continuity, which appears to be (2) ohms setting. I get Beep and .002 Ohms.
This seems to be very low ohms.
I do find it difficult when any information on testing transformers says check with the data sheet. I\'m sure someone will say sure here is the information its easy to find.
Does .002 Ohms seem right for the primary.
