S
server
message unavailable
On 2018-06-13 03:02:50 +0000, abner...@ieee.org said:
On Wednesday, June 15, 2016 at 9:41:35 AM UTC-6, silverdr wrote:
So far I downloaded and installed the ispLEVER from Lattice, which is
still available and supports \"obsolete\" devices like GALs. The problem
is that when I try to do some synthesis using
ispLEVER/PureVHDL/Synplify/ project I get output like:
Starting: \'C:\\ispLEVER_Classic2_0\\ispcpld\\bin\\Synpwrap.exe -e r512vhdl
-target ispGAL -pro \'
Copyright (c) 1991-2010 Lattice Semiconductor Corporation, All rights
reserved.
Version : 2.0.00.17.20.15
Done sucessfully with exit code 1.
Error output EDIF file c:/documents and settings/silverdr/my
documents/sources/vhdl/r512/r512vhdl.edi
Error executing Synplicity VHDL/Verilog HDL Synthesizer with code 2
Done: failed with exit code: 0002.
I have the same problem... when I do Synthesize there appears the next error:
Error output EDIF file c:/isplever_classic2_0/examples/ESumRes.edi
How did you fix it?
After spending indecent amount of time trying to troubleshoot the
problem, insrtalling, reinstalling, and exchanging emails with friendly
people from Lattice, I worked the issue around by running the software
in question in a Wine based Windows emulation. As strange as it may
sound, that was the best option for me but below is a summary of my
\"research\" on the subject:
- Windows XP Home SP2 (fresh install) â no luck
- Windows XP Pro SP3 (fresh install and available updates) â no luck
- Wine based Windows XP emulation â runs (sic!)
- Windows 10 Pro 64 bit installed from scratch in a virtual machine â runs
- Windows 10 Pro 32 bit installed from scratch in a virtual machine - runs
Looks like there\'s some kind of problem with \"native\" Windows XP support.
