Microphone/sound card question
J
John Dunkley
I want to use the 'stereo' line-in of my sound card as two microphone
inputs, one microphone in each channel (left and right.)
If I construct a simple amplifier to boost the microphone level to 'line
in' level, is any compensation required or is a straight amplification OK?
I want two separate microphones to produce two independent tracks in my
software program and using one sound card will allow this if I use the
'line in' line rather than purchase two sound cards to get two
microphone inputs into my software.
JD
John Dunkley <adunkley@bigpond.com> wrote in
message news:3EFECC4E.2060807@bigpond.com...
Hasnt the sound card got a stereo mic in socket ? Most do.
Whether it requires compensation with the
line in socket varys with the mics used.
tracks in my software program and using one sound card will
allow this if I use the 'line in' line rather than purchase two
sound cards to get two microphone inputs into my software.
You could use what is basically just a passive Y adapter to
the mic input of the sound card if it has one. Basically just
connecting two mono mics to each side of the stereo mic in.
Might get a bit tricky with what are often called
powered mics tho, and quite a few of the cheap
mics are. You'd just have to allow for that too.
What a great link! - thank you!
JD
Newsy wrote:
"John Dunkley" <adunkley@bigpond.com> wrote in message
JD
John,
I understand that the consumer sound cards mostly have mono microphone
inputs, but the following link may be of help.
http://www.shure.com/support/technotes/app-soundcard.html
Rod
